![]() | Home > General (L405) > 5.0SC or 4.4SDV8 ? |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2587 ![]() ![]() |
Fuel cost isn't the 5.0 issue - range and having to fill up 50% more often is. |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
5.0 is the one to have, its the one I would have had if i could, but too pricey when I was buying.
That won't be turbo lag, suspect it's more a perception of how responsive it is to the accelerator pedal from standstill. 0-30 in 2.5s and 6.5 to 60 isn't really slow for something weighing so much.
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 718 ![]() ![]() |
It most definitely is turbo lag when you put your foot down from rest and nothing much happens and then all of a sudden you get a dollop of torque and surge forward with a lot of noise. Not a very refined or pleasant driving experience. |
Flugplatz Member Since: 27 Feb 2014 Location: Cornwall Posts: 75 ![]() ![]() ![]() |
Hmm, I think it is the mapping and calibration of throttle response, not lag per se. Trommel is, I think, correct.
...if it was lag, eventually a given throttle opening (and, granted, it feels like a lot to me) would have built enough boost to give motive power. That's what lag is...one has to wait for the turbine to spool up in response to manifold pressure from the opened throttle and exhaust gas production. That's not what happens, I think, with these cars.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1152 ![]() ![]() ![]() |
Never heard complaints like that about the 5.0SC before, really? |
Granted, I might be slightly OCD on this stuff, but, the 5.0S engine/gearbox calibration seemed...a little uncouth.
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
I agree with Flugplatz reference the calibration of the downshift on the sc. It seems to me that the 'engineers' want to make sure that the engine is well in to the torque/power band for a rapid pickup should the driver want, and therefore the down change happens early, resulting more engine braking if you are off the throttle and hence head bobbing.
