Can't see how a downstream 02 sensor can give poor idling, they are just there to check the efficiency of the cat....
The rear ones do have pretty long leads, longer than the front, if you unthread them from all round the transfer box you could swap the leads... dead easy to change.. 22mm (I think) ring spanner, someone even thought about it and made it so the plug on the end is smaller than the spanner opening which is unusual... (It's easier to get off with a ring spanner as they are usually pretty tight....
I recon your low revs is your singing throttle body as in your other post... Pete
