Home > In Car Electronics (L322) > Changed analog to digital
Wagon mark
2006 Range Rover Vogue SE Td6 Santorini Black
Got myself a new digital TV upgrade
For my 06 td6 SE removed old unit and fitted new hybrid unit and after a lot of f ing and blinding cuts and a couple of hours gotit up and running bits tunned in some channels and played OK but every time I go in to settngs the region keeps going back to Poland after keep setting it to UK and then gives me loads of options of pal like pal b pal c pal m what do I need or what am I doing wrong thanks In advance
Post #377114 13th Mar 2016 12:11am
Should be just plug and play , when you set your region to UK it will know to set to PAL , fitting is just undoing a few cradles one of the easier jobs . When I moved mine to australia I changed the CCF for this country with my iiD Tool but in Europe you shouldn't have too . It sound like yours isn't remembering the region setting so maybe there is a power interruption , also when you do have it set to UK do you autotune it ? 2008 MY Supercharged
Post #377138 13th Mar 2016 4:07am
