Home > My Range Rover > None of your rubber band tyres here . . .
rar110
I have the compomotives here in oz. it seems they're not to common on a L322. Very happy having more tyre options and side wall to help the shocks on our corrugated roads.
I came from 19"s so didn't really notice a change.
I've also got 265/60/18s which are a lot more common here, as fitted to Toyotas etc. ______________________________
Post #402300 28th Aug 2016 9:34am
2nd Rower
Australia 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Did they fit straight on; or did you have to do any mods to get them to fit?
I assume the brembos are the same on the 2010 facelift as pre 2010?!
Post #402303 28th Aug 2016 9:38am
Compomotive 18" wheels will fit over the four pot Brembo's without having to move the counterweights like on the Sport but they can't fit over the six pot Brembo's fitted to TFT dashboard cars after 2010 if that makes it clear . 2008 MY Supercharged
Post #402307 28th Aug 2016 10:13am
2nd Rower
I think that makes it clear thanks! Thumbs Up Back to the drawing boarding it is then! Confused
Post #402308 28th Aug 2016 10:32am
GraemeS
The MY10 3.6 TDV8 didn't get the 4-pot or the 6-pot Brembo brakes, instead just a 2-pot sliding but I don't know if the Compomotives fit over them.
Post #402314 28th Aug 2016 11:55am
rar110
Thanks Graeme. So JLR changed brakes for the facelift 3.6, and used the same brakes on the 4.4 tdv8?
Another reason I might stick to the MY08. ______________________________
Post #402367 28th Aug 2016 8:58pm
GraemeS
No, only the MY10 TDV8 (3.6) got the lesser brakes as the 6-pot Brembos were fitted to MY11 TDV8 (4.4), the same ones as fitted ot the 5.0 SC. The MY11/12 5.0 na got the same 2-pot floating callipers as fitted to the MY10 3.0 D4, but different callipers to the MY10 L322.
Post #402382 29th Aug 2016 2:26am
2nd Rower
GoE have just replied to my query stating that the 18" will fit the 2010 TDV8!
They say the brakes are the same as the 3.0SDV6.
Post #402502 30th Aug 2016 4:42am
To be honest you won't have a problem , if you car is as you describe, ie a 2010 TDV8 for that year the Brembo brakes were removed and a simpler sliding caliper was fitted , when they were changed again the next year they went up to the six pot Brembo which are the only size that won't work . 2008 MY Supercharged
Post #402551 30th Aug 2016 10:35am
