Home > In Car Electronics (L322) > MP3 CD's
steadyaway
MP3 CD's
Woo hoo. Just tried an MP3 CD in my autochanger and it plays. 😊
In the absence of being able to stream music from my phone without spending silly money, this will do for now.
Post #359678 29th Nov 2015 11:09pm
Zirconblue
they do indeed, Smile
Post #359688 30th Nov 2015 12:17am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
I use iTunes to create a cd mix then use iTunes to burn the cd.
Post #359697 30th Nov 2015 2:27am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
What year is the car. My 2006 would not play mp3 tracks on CD's that I had burned so I'm using the iPod in the rear aux socket. I have a lo of mp3's burned to CD's so would be really useful if I could get the player to work.
It plays regular, or burned CD's without a problem. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #359703 30th Nov 2015 7:02am
MP3 CD's are a bit temperamental, but should work OK
If you already play copies, then you're part way there as you have discs of a brand that it likes Thumbs Up
IIRC all files need to be in the root - it doesn't support folders & it doesn't like spaces in the file names
Post #359705 30th Nov 2015 7:48am
V8Noise
Thanks Alastair. I believe mine are in folders, 1 for each album. I used windows media player to do the biz.
Looks like I'll have to do it from iTunes or live with the iPod way. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #359708 30th Nov 2015 8:30am
Weegie
When burning MP3 discs I burn them as "data" rather than music discs. It was recommended to me. The only problem with MP3 discs I have found is they can be a bit slow in loading. John
GAP iiD BT-Sold
Post #359709 30th Nov 2015 8:36am
mzplcg
Yep, data rather than MP3. No folders - that never works. And use decent blank CDs such as That's Audio (excellent media) or similar high quality stuff, i.e. not supermarket specials. The cheap ones are much more prone to skipping in my experience.
If you can be bothered, using a decent burning software package helps loads, and if you have the patience slow the burn speed down to 4x. I found vastly better results with Exact Audio Copy than I ever got with Roxio and it was really noticeably better audio quality if I was just doing a straight copy of a CD.
Post #359715 30th Nov 2015 10:02am
supershuttle
Burn as slow as possible that worked for me on my 2007 Thumbs Up Geoff
Post #359722 30th Nov 2015 10:23am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
You CAN use folders, but only 1 level - I do this as you can only put a certain number of tracks in each folder (I think it is 20, exact details are in the documentation available on 'topix') Thumbs Up Thumbs Up
They do seem to be sensitive as to what discs are used however, i have burned some TDK ones no problem, but bought a new pack of TDK discs recently (from a supermarket) and the won't work at all Big Cry Big Cry 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #359787 30th Nov 2015 3:55pm
steadyaway
It's a 2006 with the touch screen. I burn my discs as data using Nero. No folders or sub folders using Datawrite discs. Make sure the settings are not set to "Multi session".
Post #359896 1st Dec 2015 4:13am
I have plenty in my root and in folders and they work fine. Worth spending some money on 6 decent quaity re-writable discs. Tuff Discs used to be good and i still have one kicking about i use as they take a lot of abuseand marks that come from swapping them out Smile saves wasting so many cd's when you change what you want to listen to.
I am however still surprised that to this day no-one has come up with a way to replace the CD changer with a HDD unit, ideally a nice SSD or USB based one for much quicker and easier updating. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #359912 1st Dec 2015 11:34am
they have Will,
http://www.fullfatrr.com/forum/post359766.html#359766 ... - .- -.
Post #359918 1st Dec 2015 12:29pm
Zirconblue
fitting the Land Rover ACM is easy, that gives you ipod connectivity, SD card slot, USB etc. It's just expensive. Laughing
Post #359927 1st Dec 2015 1:51pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
Did any one ever tried playing MP3 CDs in the DVD player - my cars CD changer doesn't work. The cd changer keeps giving "disc error" message
Post #360888 7th Dec 2015 5:57pm
