Home > Technical (L322) > Manifold Absolute Pressure sensor 4.4 M62 |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
...."valve mounted at the rear of the inlet manifold."
21st Nov 2015 12:42pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
It's a combined sensor mass air flow (MAFS) and intake air temperature (IAT) it's the same as a MAP sensor...
21st Nov 2015 1:12pm |
To explain a bit more, early fuel injected engines had a MAP, they soon changed to a MAF as they are far better and measure more so you haven't got one on an M62 but you have got a MAF.... if that makes sense....!!! Pete
21st Nov 2015 1:18pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Hang on though, a MAF meter and a MAP sensor don't do exactly the same thing. The MAF measures the volume of air entering the engine, the MAP (where applicable) gives the intake air pressure - on cars with forced induction. The 4.4 V8 is naturally aspirated, so there's no real need for a MAP sensor. Visiting from DISCO3.CO.UK
21st Nov 2015 2:13pm |
Oh, OK then, I'll shut up..... Pete
21st Nov 2015 2:29pm |
Please don't take it personally though. Visiting from DISCO3.CO.UK
21st Nov 2015 2:32pm |
I was answering the question in a way most folk would understand it, I said "it's the same as a MAP sensor..." what I should have said is they both do basically the same thing, they tell the engine ECU how much air is going into the engine...
21st Nov 2015 5:02pm |
Yeah, I know what you're saying and wasn't meaning to contradict that side of it.
21st Nov 2015 5:37pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Reminds me of the posts you see on classic car forums regarding Ameters vs. Volt meters.
21st Nov 2015 6:08pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 337 |
Hi Guys
22nd Nov 2015 8:38am |
Quite a good analogy actually, because while each can be used as a measurement of the same, they are also tasked to to different things. A MAF can skin a cat better than a MAP, but a MAP is also used for skinning dogs!
It varies though. I've cleaned (ish) my MAP a few times, but would touch the MAF unless it was already faulty, because it's extremely fragile. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
22nd Nov 2015 10:07am |
Clean a MAF by jet washing it with carb cleaner, you have to do it more often if you off road...
22nd Nov 2015 1:03pm |
Exactly that, they just wash out with carb cleaner, but i certainly wouldn't consider mechanically cleaning it, as they are indeed fragile, but carb cleaner usually brings them up like new. |
24th Nov 2015 9:58am |
Even that would be considered a risk for mine though. Visiting from DISCO3.CO.UK
24th Nov 2015 12:07pm |
