Home > In Car Electronics (L322) > Select neutral
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Select neutral
First time i have seen SELECT NEUTRAL come up in display panel ? Any ideas guys.
Post #357688 19th Nov 2015 8:48am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Have you knocked the low box selector switch?
It will not engage until you are in neutral. Mine was a blue one! Smile
Post #357691 19th Nov 2015 9:17am
brian1951
No Andy seems not, it only displays for a few seconds. Never seen it before and i have had it 9yrs.
Post #357692 19th Nov 2015 9:23am
craig reckons it could be the hi-low motor going kaput,
http://www.fullfatrr.com/forum/post178091.html#178091 ... - .- -.
Post #357693 19th Nov 2015 9:32am
brian1951
Thanks for that link Stan, i was pulling fuses yesterday doing another fault.
Post #357695 19th Nov 2015 9:41am
mike whiskey
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
I get this occasionally, it seems to tie in with days when the 'Air Con' Puddle under the car is bigger. I am putting it down to water ingress in the wiring around the gear box.
I'm going to wait and see if it happens again now that I've had the car undersealed.
MW Car history includes: LR Series 3, RR Classic x 4, LR 101, Discovery 1 and 2 and now FFRR.
Yes I'm a masochist....
Post #357705 19th Nov 2015 11:04am
brian1951
I will join you Mike wait and see Bow down
Post #357714 19th Nov 2015 12:09pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
make sure you have not put the fuse in for towing ,very easy to do,wants you to select neutral so it can put transfer box into neutral for towing
fuse 37 in glovebox on early ones == ONLY FITTED FOR TOWING
just a thought
nige
Post #357723 19th Nov 2015 3:27pm
brian1951
Thumbs Up Many Thanks Nige you were 100% correct, i will sleep better tonight thanks to your help. Regards Brian. Thumbs Up
Post #357728 19th Nov 2015 4:07pm
ironhorse
Thumbs Up been there ,done that ,lol
ive put a blob of tipex on fusebox 37 to remind me not to put a fuse in that position
Post #357731 19th Nov 2015 4:19pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I know this is an older post but it just helped me.
Took my FF in to garage to have locks and keys changed after spare was stolen, they told me it had been taken to a Landrover dealer to have new keys coded after fitting. When I picked it up I got the signal "select neutral" and then "slow down". The car seemed OK so I drove it home. Same thing happened when I started it again. I assumed the onboard computer was playing up with the new keys.
Anyway, before I took it back, I searched the forum and found this topic. Sure enough there was a fuse in the 37 slot, problem solved.
Anyway, thanks. This forum came to the rescue again.
I think I will still go back and speak to the service manager though. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #425231 28th Jan 2017 3:29pm
