![]() | Home > In Car Electronics (L322) > Sat Nav - "Temperature Error, shutting down" |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
thanks for the update. |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 780 ![]() ![]() ![]() |
Well I thought that all my probelms were solved when a replacement head-unit appeared on eBay last week at a very good price. It duly arrived and I set-about removing the whole dashboard assembly after watching several youtube videos on 'how to'..... Unfortunately, the videos were all for a 2006 vehicle and I can tell you that there are several diferences with a 2008 vehicle, although the basic premise was the same.
adamjcooper1 Member Since: 08 Apr 2018 Location: cannock Posts: 2 ![]() ![]() ![]() |
Just wondering if resolved issue, as mine still occurring
It's only taken me four years, but I believe I have now fixed this today! |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Good news JMC |
mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133 ![]() ![]() ![]() |
Hi, I have had the same problem fitted a loop to the TV unit Today and problem has gone. |
A few days on, a good few miles and countless ignition cycles since changing the hybrid TV unit. Problem is definitely solved. Chuffed to bits. |
Hi JMC,
Hi,
LiamCuz Member Since: 25 Mar 2020 Location: Northumberland Posts: 4 ![]() ![]() ![]() |
Hi guys
TTF Member Since: 06 Feb 2012 Location: Wiltshire Posts: 130 ![]() ![]() ![]() |
If you don't use your TV just put a prism in line which effectively bypasses the TV unit and the total system should work fine. RR 3.6 TDV8 Vogue SE
Ecovandal Member Since: 08 Jul 2022 Location: Perth Posts: 1 ![]() ![]() ![]() |
I have been having the same issue. How does one fit a "loop" to the TV unit or a "prism" in line. I am happy to not have the TV unit if this will fix the shutting down. |
Gary N Member Since: 12 Oct 2022 Location: Devon Posts: 2 ![]() ![]() ![]() |
I'm also having the same issue on a RR I picked up last week.
Gary,
