Home > Technical (L405) > USB stick problems.
USB stick problems.
My USB stick works in the back of the car and it is recognised correctly - not so in the front ....
Any ideas ??? Crying or Very sad Crying or Very sad Crying or Very sad All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #357275 16th Nov 2015 5:48pm
I've only used the front one for loading POI's (speed cameras) and it needed to be formatted as FAT32 - it didn't recognise the stick from my Mac
Not sure if there is also a size limit - I only used an 8Gb one
Post #357276 16th Nov 2015 5:49pm
pld118
Re: USB stick problems.
XXXAngelXXX wrote:
My USB stick [isn't working] in the front [of the L405] .... Any ideas ???
Chop it in for an L322. They might even still have your old one for sale Rolling with laughter
Post #357279 16th Nov 2015 5:53pm
@Alistar: it is formatted Fat32 since it works on the back seats - i am not a DUE (dumbest user ever) Laughing
@pld118: pfftttt Rolling Eyes Laughing Thumbs Up All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #357285 16th Nov 2015 6:30pm
Big assumption that the front & rear systems are compatible Whistle
I have no idea, but have owned a RR long enough Laughing
Post #357293 16th Nov 2015 7:06pm
wilwak
United Kingdom 2016 Range Rover Vogue SE TDV6 Corris Grey
Loading Speed Cameras? Fab. How do you do that?
Post #357304 16th Nov 2015 8:23pm
I am interested in the Speed cameras thingy.
Beside even if i take another stick - it doesn't recognise it correctly - it shows the titles but doesn't play them Sad and still only in the front.... All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #357308 16th Nov 2015 8:34pm
You might find something in here relating to your problem Frank ... Scroll down to Portable Media Thumbs Up
If not might still be useful for L405 owners ... before someone shoots me down i know its for 2016 models Whistle
L405 INFO
Post #357311 16th Nov 2015 9:02pm
PM me your email & I can send you a sample
Basically a subscription to Pocket GPS World then download the GPX format files, unzip, stick on a USB stick & load them as custom POI's
It works OK for fixed cameras - you can see them on the map & set an audio alert - but the alert works on the map - so it goes of regardless of where the camera is - so sometimes you get them for adjacent roads. The choice of available sounds is awful - there are only 3 on the FFRR - 2 that sound lime door bells & 1 that sounds like an ice cream van - instructions are the same as the Jag ones
For the mobile cameras, the audio alert is too late - but it will display them on the map.
Annoyingly they won't pop up on the instrument display, just the main map
There are multiple file types - Gatso (fixed), Specs (average speed), common mobile sites & red light - you can either download a single file for all, a file for each type, or detailed files for each type (i.e. by speed limit)
Files are UK and/or Europe & you can elect to have Swiss & French or not - as it's illegal in those countries
Coverage on at least the autoroutes in France seems very good Whistle including regular mobile spots Thumbs Up
There are regular updates - you can download as often as you can be bothered to.
Post #357323 16th Nov 2015 9:47pm
IanT599
Would the speed camera locations work on the L322? Or is there a version for the L322?
Post #357325 16th Nov 2015 9:57pm
Sorry- don't know - maybe on later models
If there's a USB port - and the sat nav has the ability to add personal POI's then I can't see why not
Post #357326 16th Nov 2015 9:59pm
wilwak
Unnecessary quote removed
Brilliant. Thank you.
Post #357664 18th Nov 2015 11:58pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
As for Franks original question , it doesn't make sense that your USB stick works in the back but not the front . I'd suggest maybe the car entertainment software needs checking to ensure it is recognising the front USB port in the first place (have you checked for loose connections to that USB port?) . I have an issue whereby whenever I play a CD /or play an uploaded one , it always shows the title of the one saved in the last slot (10) no matter which one I play , kind of annoying , it does show the correct track number though. I assume this is a bug in the factory software so this may be the case for you (but with a greater impact). I think you need other forum uses who have 2 USB ports to test theirs and confirm back to you. @Alistair - I use a 16Gb stick in the car with no issues , also have a directory on it with all the POIs. For POIs on L322s, I assume the later ones had the hard drive Sat Nav systems so guess if they also had a USB port in the car, there is a chance the POIs could be uploaded. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #360037 2nd Dec 2015 12:15am
Thanks for your advice RRVSE: my car is in at the dealer for this week to get all kind of things sorted out - i hope they will get all done.
When i use the front USB slot it shows the titles but doesn't start the songs - kind of weird and in the back it just works normally. Mad All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #360053 2nd Dec 2015 8:50am
RRVSE
No problem Frank. Let me know how you get on as if they fix your USB software issue, there is also a chance they can correct my CD 'title' issue aswell. Steve
Post #360280 3rd Dec 2015 4:37pm
