![]() | Home > For Sale & Wanted > [SOLD] 19" Range Rover Vogue Alloys with Scorpion Z |
Zigzagsky Member Since: 18 Oct 2015 Location: Sandhurst Posts: 39 ![]() ![]() ![]() |
Are these for the 02-05 cars or the later ones? I think the offset is different 2005 Range Rover L322 TD6
Martyn Member Since: 10 Mar 2013 Location: Poole Posts: 65 ![]() ![]() |
I had them on my supercharged (05/06) but they're from a 2010/2011 car. 2013 FFRR Vogue SE |
Damn! I was looking for a set of wheels for my 2005 which is pre facelift. 2005 Range Rover L322 TD6
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
they will fit,you just need later nuts 2007 tdv8 se ,stornaway grey |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2051 ![]() ![]() |
Not for a 4.4 tdv8 I'm afraid |
I thought the offset was different, is that not the case? 2005 Range Rover L322 TD6 2009 Jaguar XK 5.0 Portfolio 1969 Jaguar E Type Series 2, 2 Plus 2 |
Ok, done some checking and the offset is the same (57mm) but as mentioned, new wheel nuts required. 2005 Range Rover L322 TD6
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
I had a set on my 2005 pre facelift which are now in storage pending winter tyres or new summers! |
I can pop these on a pallet if the drive to collect is too far.
Cat_81 Member Since: 02 Jan 2016 Location: Kent Posts: 10 ![]() ![]() ![]() |
Martyn do you know if they would fit a 4.4 TDV8 MY 2012? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
No they won't, unfortunately. there is only one style 19" which will
Lol. You may have figured I need winter tyres and a new set of wheels by now ... |
you and me both, though I have a head start as I had some new 19" Scorp winters last year on the same wheels the OP has for sale..... So I'm sorted for tyres just need rims! they are either expensive or miles away at the moment, when i see them on the bay of E. There is nothing that can't be fixed with a hammer😜😜
