![]() | Home > Maintenance & Mods (L322) > TD6 Exhaust |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
What are you trying to achieve by changing it? |
jody1476 Member Since: 28 Oct 2015 Location: Chipping Norton Posts: 4 ![]() ![]() ![]() |
Hi
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Be aware that I believe it is now illegal to remove EGR's, and can result in a refusal to issue an MOT AFAIK. |
I'm not sure, there's nothing in here about EGR valves. I have a DPF (which if removed is an instant fail) so no smoke from mine
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
Have you had a DPF fitted because they didn't come with one as standard..?? Pete
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7904 ![]() ![]() ![]() |
I didn't think testers could strip stuff down during the test, and I'm pretty sure the acoustic cover would have to come off to verify egr removal...... Could be wrong. 2011 Range Rover Vogue SE 4.4 TDV8
I assume I have as I don't get any smoke at all. MOT test on diesel is smoke test, at least it was |
It's too old for a DPF, changing the back box won't have much effect on performance and won't make it sound much different, the turbo mutes the noise anyway...
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Your not confusing a DPF with a CAT? Yesterday I couldn't spell Engineer... Today I are one!
chaybra Member Since: 09 Feb 2014 Location: Melbourne Posts: 33 ![]() ![]() ![]() |
I chopped mine off and added some pipe..sounds much better, turns heads even
You mean from this
Are you going to share the noise with us all, or just leave us guessing? |
