Hi all.
Looking some advice and help with regards to changing the time to 24hr display and date to European ddmmyy format.
I have 2004 non touch screen vogue.
On recently changing the battery I went to set screen to reset the date and time etc. The options to change the format are showing but when I press select it does not change. Everything else appears ok.
I have already tried a dashboard reset and a battery disconnect to no avail.
Which ecu stores the date/time memory and can it be reset or reprogrammed.
Thanks.
