Home > Wheels & Tyres > Uneven tyre wear - can a wheel bearing cause it?
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Hi all,
As you can see, the rear tyre is wearing very unevenly on my RR - the outer shoulder is almost bald, whilst the inner shoulder (and the rest of the tyre) is almost full depth:
Now, obviously the first thought would be to get the tracking checked - and I'm already looking to do so. But I have noticed recently a bit of a grumble at motorway speeds or when cornering, which I think is a rear wheel bearing on its way out. Would a slightly grumbly but not catastrophically knackered bearing be able to cause this sort of damage to the tyre by letting the wheel assume an extra degree of toe?
Thanks,
Matt
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #353014 19th Oct 2015 8:42am
The rear tyres on mine went like that, the rear camber is supposed to be set to around -2 deg, I readjusted mine to + 1 deg and the wear is now even, the turn in is now much better as well.....
I used a very scientific way of doing it... the compass app on my iPhone, it has a spirit level on it and tells you how many degrees off vertical you are...
Would have thought a wheel bearing would be making all sorts of noise before it increased wear on a tyre.... Thumbs Up Pete
Post #353016 19th Oct 2015 8:52am
Shandonman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
FWIW I had a rumble from one side recently. Was convinced it must be a wheel bearing on its way out. Took it into the garage and the tyre was like yours. Put a new one on and the rumble has gone.
So fixed the rumble but never diagnosed why the tyre is wearing more on the outside. 2002 Vogue 4.4 V8
1995 Disco 1 300tdi
Post #353021 19th Oct 2015 9:24am
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Mine did exactly the same as this and it turned out to be the rear suspension bushes
Post #353257 20th Oct 2015 8:38am
Obviously more than one reason does this then as my bushes were all new just before the tyres, and it had a four wheel laser alignment and was adjusted to factory spec...
I still recon it's the factory settings that are wrong, my rear tyres have worn totally evenly since adjusting the camber... Pete
Post #353268 20th Oct 2015 10:06am
