![]() | Home > Technical (L405) > Can anyone else hear their fuel tank? |
pjb Member Since: 15 Feb 2010 Location: Sunny Oxon Posts: 244 ![]() ![]() |
I'm sure I've heard before about fuel sloshing, will find the link
Chaffers Member Since: 04 Feb 2015 Location: South Bucks Posts: 14 ![]() ![]() ![]() |
Ahh thank you - at least it isn't just me! |
wilwak Member Since: 02 Oct 2015 Location: Hampshire Posts: 27 ![]() ![]() ![]() |
I took delivery of a brand new L405 last week. The 3l diesel model.
On an £80k+ vehicle is it really acceptable for such things to still be happening? I have £400 cars that dont make tank slop or smell of fuel inside and they are 20+years old and french |
d3rm0 Member Since: 12 Feb 2012 Location: UK Posts: 440 ![]() |
I had to have some sort of sound deadening fitted into my 13MY and I am now amazed that my 15.5MY does the same thing. The car smells of diesel for quite a long time after the fix. |
Not being funny but if it was mine and it smelt of fuel it would be straight back to the dealer under unsuitable for use, personal h&s from the fumes but mainly if you can smell diesel and it's somewhere on the vehicle I'd be worried about it being near a hot exhaust part.... Even if they have spiller some during work they should have cleaned it off with some petrol or such and job done... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
EdJ Member Since: 30 Jan 2015 Location: London Posts: 363 ![]() ![]() |
I have noticed the fuel in the tank sloshing back and forth. Usually I have the radio on so don't hear it but was surprised that I did hear it the other day. Not noticed any fuel smell though - that would be more worrying... 2024 Range Rover P550e AB |
Yes, the fuels slops around but it's a fantastic vehicle. Makes me feel a million dollars driving it.
scott4197 Member Since: 07 Oct 2013 Location: Wolverhampton Posts: 58 ![]() ![]() ![]() |
It is possible that LR forgot to fit foam baffles in your fuel tank when they built the car. There is a remedy - SSM66137 - to correct this. It involves removing part of the rear seat squab, removing the fuel pump from the top of the fuel tank, and stuffing foam baffles into the tank. If you get this done, I suggest bringing the car to the dealer with the bare minimum of fuel in the tank. That will give them less to spill when doing the remedial work. |
MattyB Member Since: 01 Sep 2015 Location: London Posts: 16 ![]() ![]() ![]() |
Ah, that's what that sound is??!!!! I heard it a couple of days ago for the first time (I normally have music on so can't hear anything). If I am stationary then pull forward or backward and brake hard I can hear what I thought was a soft banging sound underneath but now you mention fuel slopping in the tank, that is almost certainly what it could be.... Ridiculous in a luxury car like this. Grrrrrr!!!!!!!! |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
There's no 'forgetting' to fit the foam baffles at the factory. LR are actively building vehicles with this problem because the fix is too manual for the production line. They know that every L405 and L494 that leaves the factory has this problem. It is worse with the 80L tank AFAIK. |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
I have this on my 13 plate, dealer said it was a problem.on early ones and the fix is the baffles that newer ones get from the factory, yeah right lol |
I can't believe they haven't addressed it.
They also don't tell you it reduces the capacity of your fuel tank. |
