Home > Technical (L322) > 4.4 Gearbox issues "trans fail safe prog" + others |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
I have been trying to troubleshoot a gearbox issue I have with a 2003 4.4V8. I bought it on the assumption that the gearbox was screwed but on driving it I discovered the gearbox itself seems ok. I was getting the "trans fail safe prog" & it goes into limp mode & 4th gear mostly upon moving selector from park to drive. If I turned it off & put into neutral, then start it was ok but then sometimes wouldnt start. On occasion it would do it over & over, other times you can start the car drive 40 miles with no issue. It also does it from cold too, sometimes as soon as you engage gear. I thought it must have been the xyz inhibitor switch. I removed it, drilled out the rivets & got a chap to test it & it passes the continuity test so appears fine. If it's not that then what could it be? Test drove it & it stopped going onto trans fail safe when I went from park to drive but then does it driving Like say a min later.
26th May 2015 5:17pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8284 |
I'd say it's the Hi/Low motor on the transfer box, it uses canbus for most of it's operation so if it isn't getting the right feedback then it will do all sorts of funny things to the rest of the gearbox system...
26th May 2015 5:30pm |
I did test it as in that vid & it seemed to be ok but I'm kinda thinking the same thing. I just don't want to fork out for one to find its not that. 2004 RR 4.4 V8 Autobiography |
26th May 2015 7:26pm |
Yeah, there not cheap even second hand, this is what Rave has to say about the transfer box ecu and errors connected with it, does this sound like yours??...
26th May 2015 11:33pm |
The low range mountain symbol does not stay on, in fact it doesn't even come on at all even when trying to select low range. 2004 RR 4.4 V8 Autobiography |
27th May 2015 7:44pm |
haven't a clue then, could be anything.... Ecu, motor, tranny box..... Pete
27th May 2015 8:19pm |
Tried disconnecting the low box motor but made no difference. Well in fact I didn't get very far in it as if kept going into limp mode straight away. Once removed, does the low box motor need calibrating after refitting? Pretty sure I read something about it somewhere. Also can it be re-fitted incorrectly? 2004 RR 4.4 V8 Autobiography |
29th May 2015 5:49pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
7th Oct 2015 2:46pm |
PaulNorway Member Since: 12 Oct 2015 Location: Oslo Posts: 3 |
Is it generally the best thing to have electronics check on the computer first. |
12th Oct 2015 12:18pm |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 |
To me, this sounds like a wiring fault, or water getting into the wiring or switchgear. Have a good look around underneath, especially for chafed wires or water ingress, (The Air Con drains being a prime source....)
12th Oct 2015 12:25pm |
I did wonder that myself Mike about wiring fault, I have had a good look under there but whereabouts are the air con drains? 2004 RR 4.4 V8 Autobiography |
15th Oct 2015 8:18pm |
