Home > Maintenance & Mods (L322) > managed to de-program key |
You need to code all your keys immediately one after the other |
8th Oct 2015 6:52am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
There is a nack to it too... Can take several attempts |
8th Oct 2015 7:17am |
sherman Member Since: 23 Aug 2015 Location: L'Isle Jourdain Posts: 71 |
Ya thanks guys, turned out the key I had the new battery put in needed adding with an Autologic box. Once that was done, the ignition recognised it and was able to switch the ignition on. This confirmed the blade was ok and the transponder was working. So, following the threads on here, I persisted, and tried several times to reprogram them, and finally, success........
8th Oct 2015 9:17am |
