Home > Maintenance & Mods (L322) > Front Control arms changed |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
Was toying the idea of changing my same parts as the rears have been done, but I don't know the front ends' history. All driving ok though. Just don't want o junk my new tyres.
6th Oct 2015 8:07pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Pattern. £109. |
6th Oct 2015 8:15pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
Just changed mine, went OEM with the arms with ball joint attached and then just got the bush and ball joint for the other arm, both sides was under £200... was a right pain pushing out the old bush in the arm though, took well over 10tons to get it out!!! Pete
6th Oct 2015 8:49pm |
You can't put a price on pain... Must remember to move thumb when hitting ball joints in confined spaces.
8th Oct 2015 12:08pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
ouch! ... - .- -.
8th Oct 2015 12:20pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
working offshore there'd be a massive inquisition about that (the thumb hit) these days and you'd feel like you'd broken into the palace and been caught on the queens pillow.
8th Oct 2015 12:43pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
Done a few of these type of jobs where it looks like it will never come off and I have started spraying everything in wd or equivalent 2 or 3 times sometimes a week or two before doing the job if that is possible.What I have found is by spraying up like this you will not believe how much difference it makes to a job.Just done rear shocks on my old 18 year old van with nots half rusted away,got the blowlamp and grinder ready to cut bolts but due to spraying up I didn't need either,just tap off rust ,tap on a socket to fit and came straight off !! |
8th Oct 2015 7:03pm |
PeterY Member Since: 01 Feb 2015 Location: Oxfordshire Posts: 21 |
just trying to do this on mine, arms are easy but the ball joint in the upright will not budge, been hitting it for 2 hours now and no movement at all
20th Oct 2015 12:58pm |
A jack under the upright to hold it firm so each hit actually impacts fully on the ball joint - plus a thin wide bolster hit between the "wings" of the joint and the upright.
20th Oct 2015 5:32pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
ball joint fork or take it to a garage..... There is nothing that can't be fixed with a hammer😜😜
20th Oct 2015 7:31pm |
Ball joint tool isn't of any use as It's not a ball joint that's seized , it's the ball joint body/holder that's stuck/seized in the lower wheel flange |
20th Oct 2015 9:09pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
I use a pointed end chisel to hit downwards into the casing of the balljoint, and as mentioned above, a flatter chisel in at the wings.
20th Oct 2015 9:53pm |
