Home > Technical (L322) > L322 4.4 TDV8 burnt oil smell in cabin and outside |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 |
Help!
30th Sep 2015 6:19pm |
Finally got the car back from the independent garage and apparently they changed the oil cooler and a pipe - my question is can they do this without having to change the oil?
17th Oct 2015 9:41am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Wow... So the pipe with the “O” ring was not at fault? Or the pipe with the “O” ring was what was changed along with the cooler etc |
17th Oct 2015 9:47am |
Craig - I'm in he dark about what has been changed - I was told a new oil cooler and pipe (apparently £600 cost?) but I'm still baffled as they left the car low on oil - I would have though they would have needed to drain the oil first and hence filled with oil again? CURRENT : FFRR 2012 4.4 TDV8
17th Oct 2015 9:49am |
Well, its on top of the engine so the job could be done without draining the oil BUT... I wouldn’t have let the car go out without an oil change if only to make sure anything that could have contaminated the oil whilst changing the cooler was removed... |
17th Oct 2015 9:54am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Will have to get the camera out on mine again as there was a very distinct hot burning smell when I just got out!
25th Feb 2016 6:41pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Ah yes, the oil cooler in the V.... £1097 later mine was fixed. Garage just bought another 4.4 with the same issue. I think the oil cooler is about £380 plus vat from Land Rover, then the labour and oil change and coolant flushes as oil was in my coolant....
26th Feb 2016 5:38pm |
Smell has gone not sure it was my car! Was parked in a car park.
26th Feb 2016 9:21pm |
NICKJC Member Since: 13 Feb 2017 Location: Kent Posts: 9 |
Hello - I have just registered on the forum after being led here by Google search "L322 Oil Cooler Problems"
13th Feb 2017 3:16pm |
Sorry forgot to add that I have instructed the dealer to lodge a claim with LR UK for a contribution....will let you know if that succeeds!
13th Feb 2017 3:32pm |
tvrforever Member Since: 09 Feb 2016 Location: Bucks Posts: 55 |
hmmm mine's back in to JLR main dealer when they discovered an oil leak during service (but didn't rectify it) - shall be an interesting discussion about warranty and main dealer quality I suspect |
19th Feb 2017 5:24pm |
JLR came up with a contribution as a goodwill gesture.... |
23rd Feb 2017 7:23am |
FlyingTrotter Member Since: 10 Nov 2013 Location: London Posts: 79 |
This could be the same issue i have - small amount of oil under centre of car and smell noticible in cabin more when pull away from stationary in traffic - will take it to the independent |
17th Feb 2019 4:40pm |
Hope you still only have water in your coolant.....
17th Feb 2019 6:15pm |
