Home > Technical (L322) > Help 2007 to 2010 headlight conversion wiring!!!!
T10yyy
2007 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Hi everyone. I have a 2007 vogue 4.2 and currently in the middle of doing 2010 conversion.
My original headlights had AFS and the 2010 ones also do. I have rewired the headlights to supply the +ve and -ve to side lights, headlights and indicators. They all light up fine however the indicators flash and so do the aide lights intermittently. I tried adding a module from eBay which didn't solve the issue. I have now ordered 22ohm resistors to see if they will help.
My main question is does anyone have the wiring diagram for the 06 to 10 conversion. On here it's all about the 02-05 to 10 wiring which is no use .
Also I belive all xenon lights should have a self leveling system which in don't think I have wired up. There are still 3 or 4 wires from my old connector which are unused still. Are these tondo with afs or self leveling and how Do I go about connecting them?
I hope someone can email me the wiring diagram for the 07 to 2010!
Post #349447 25th Sep 2015 11:34pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi mate,
I have a 2003 Range Rover but I had fitted the 2006 face on it a few years ago then I upgraded it again to the 2012 face, I posted a very detailed conversion instructions on here is wiring diagrams, it might be of use to you.
Also to note the only model with self levelling lights was the original 02-05 square headlights, all the others just have manual adjusters apart from the AFS turning lights witch do the up/down dance when you power them on.
Hope this helps
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #349523 26th Sep 2015 6:25pm
defenderv8t
Greece 2006 Range Rover Vogue 4.2 SC V8 Barolo Black
Good morning,
I really need you help,,,
I convert my 2006 SC to 2010 , i have problem with the dash light flashing AFS,
do you suggest something?
Best regards
Post #465084 19th Jan 2018 10:09am
Turn the AFS system off in the CCF files sir Thumbs Up
Post #465098 19th Jan 2018 12:04pm
defenderv8t
thank you for your reply!!
is this posible through Gap tool only?
best regards
Post #465099 19th Jan 2018 12:13pm
defenderv8t
What is the best tool for this?
Post #465123 19th Jan 2018 1:53pm
verydisco
That would be the IID tool indeed. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #465124 19th Jan 2018 2:00pm
defenderv8t
Do you mean with gap or ids or sdd?
Thanks
Post #465125 19th Jan 2018 2:07pm
defenderv8t
Regarding the turn signals
Does anybody know why the work when engine is not running? When you start the engine only the front turn signals stop working.
Post #465145 19th Jan 2018 5:03pm
