Home > General > Stolen Range Rovers In Uganda
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #350729 5th Oct 2015 12:42pm
wilwak
United Kingdom 2016 Range Rover Vogue SE TDV6 Corris Grey
My FFRR is brand new so has the latest updates on it. I checked.
I'm told that older L405 can have the keyless module within the car upgraded to the latest one which doesn't allow new cloned keys to be made from the diagnostic port.
They're now read only apparently.
Isn't Land Rover recalling all L405s to have the updated module fitted? I heard that they were.
My car has a tracker built in. I can track it using the Range Rover Connected App on my IPhone.
Post #350749 5th Oct 2015 2:07pm
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
GPS trackers are not worth much nowadays. You can easily get a GPS signal jammer.
Post #350841 6th Oct 2015 7:50am
Thats good news... Sounds like a step in the right direction Thumbs Up May i ask how you came by this info? And is it reliable? Don’t mean to seam doubtful! Its just the first time i have heard of it sir Bow down
Post #350843 6th Oct 2015 7:57am
wilwak
I think it was here that I saw it first...
http://www.pistonheads.com/gassing/topic.a...ty+upgrade
I asked my local dealer and they confirmed that my new L405 would already have the updated module.
They also tell me it has 6 trackers located around the car.
The first 3 years of the tracker is free but then it would be subscription... I assume.
I'm certainly no authority on it .... Just going on what I've been told.
That thread seems to suggest the module upgrade is a 'Customer request item' so not a full recall.
Post #350849 6th Oct 2015 8:43am
I too am unsure how that would work long term unless JLR said they needing to make keys at the factory tied to the exact system of the vehicle and then push the update OTA to the vehicle.
Even so, doesn't stop the brute force push method i'd mentioned/.. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #350850 6th Oct 2015 8:44am
wilwak
My understanding is that it simply prevents a new key being added via the diagnostic port.
To add a new key now you'd need to replace the module also. That would also mean replacing your old keys completely.
They had to do something. Seems like an easy quick fix to make simple key cloning more difficult.
Post #350851 6th Oct 2015 8:49am
Paul J.
My understanding is they are lumping in the replacement read-only KVM work with the P068 recall.
If you then have a genuine need for a new key coding, Land Rover will provide a new KVW free of charge.
Post #350861 6th Oct 2015 11:53am
