![]() | Home > Technical (L322) > 6hp26 gearbox problem! |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
Gearbox is toast, and needs a rebuild or replacement...
QuattroCj Member Since: 18 Sep 2015 Location: Sheffield Posts: 8 ![]() ![]() |
I've not heard of 5th being a major issue in these boxes at all. All I've gear is good review on it being built proof since its rates at 600nm torque.
Have a look at this history of my gearbox. It got sorted by replacing all solenoids although later RRPhil found out only needs to be replaced. MY 2010 5.0 SC Galway green and sand interior!!
Hey em, I've read your thread many times its like a story, such a good thread and very informal.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Please don’t put a ‘one-oil-suits-all’ fluid in your 6HP26. The bottle will probably say on it “recommended for…” followed by a whole list of just about every transmission under the sun (including many Dexron ones). The people doing the recommending are the fluid manufacturer (well they would wouldn’t they) and definitely not ZF. The controller adaptions have limits for clutch slip times. Only use Lifeguard Fluid 6 in your transmission, which produces the clutch friction properties that your transmission was designed for.
Shoot! I used a supplier that you have to put your plate in to get vehicle specific parts. I checked this fluid aganst the zf stuff and its slightly the same. It states m-1375.4 and .6 along with SP and about 700 others. The car has nothing literally nothing in it when I got it. It had about half a cup full and that was it.
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Lifeguard or Meyle: http://www.advancedfactors.co.uk/014019290...-174-p.asp |
Some more background reading that may be of interest: http://www.disco3.co.uk/forum/topic108824.html May or may not be related to your issues, but it's worth a read anyway for any 6HP26 owner. |
Thanks for those links, I've read about that post already. I'll have to do some research on that.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2651 ![]() ![]() |
My MY10 3.0 D4's box got the worn stator bush problem and needed a full rebuild/upgrade. |
I would definitely go with RRPhils recommendation on using ZF Lifeguard. Not worth risking issues by using another ATF that is "close" IMHO. MY 2010 5.0 SC Galway green and sand interior!!
Just to add, the Meyle is the same stuff, in a different bottle, and without the heafty price tag, tried and tested. |
Okay I'll do that when I get some wonga. I should get something on Monday. What do you guys recon I should do? Flush out the old new stuff and if so how? Or just drain the old new stuff and refill with the new stuff?
If your transmission has lost 4th AND 5th AND 6th gears then this would suggest a problem with the E-clutch.
