Home > Maintenance & Mods (L322) > Smoking TDV8
Geraint
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Smoking TDV8
My 2008 3.6tdv8 with 112000 miles on it is feeling poorly.
It has started smoking very heavily under heavy load during the acceleration cycle.
And drops into engine fault mode every so often.
Top hoses were changed 18 months ago after a similar issue, and I have pressure tested them and they are fine.
I have taken off the LH bottom hose and it is fine, but cannot get to the top clip on the RH lower hose so have done a good visual on it with the bottom clip off and it is also looking OK
There is slight oil inside the RH hose, and none in the LH hose, I assume to do with the breather on the crankcase.
Martin has put the bluetooth OBD plug he has onto the car and both turbos and all their associated actuators and air flow units are matched for pressures and volumes, so no obvious problems.
There is no smoke at tickover or when revs are increased at standstill, but towing my 2.7 tonne trailer at the weekend resulted in a black fog over the A34!!
It probably needs to go to Camtech for a good seeing to.
Any suggestions out there
Post #347715 14th Sep 2015 6:47pm
ebajema
Maybe the EGRs are clogging up and causing issues ??? MY 2010 5.0 SC Galway green and sand interior!!
Post #347761 15th Sep 2015 4:32am
chaybra
Australia 2006 Range Rover Vogue Td6 Zambezi Silver
Im just going to say it because it needs to be said....check air filters
Post #347763 15th Sep 2015 6:38am
rar110
I'd try a dose of Revive, particularly if you do a fair bit of city driving. I've used it twice now. ______________________________
Post #348128 17th Sep 2015 12:00am
Martin
Site Admin
I have been looking after the RR for a bit and can confirm that the air filters are fine.
The error code that comes up with the ESF is the same as when the top hoses go (P023D-21), but it is not them.
The code suggests a right hand boost leak but running the car with the IID Tool live traces doesn't show any obvious problem comparing left to right Big Cry
I don't believe there is a way to drive the various actuators (turbo actuator, I was thinking) with the IID and monitor the output?
Post #349087 23rd Sep 2015 1:57pm
Did you find the problem ?
Post #351481 10th Oct 2015 9:19am
Martin
Site Admin
Not yet, all the boost pressures look fine.
Post #353106 19th Oct 2015 3:07pm
