Home > General (L405) > Towing caravan or trailer with LED lighting
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Hi all I thought I would tell you all that if you towing a Caravan or trailer with LED lights your Range Rover will properly not know you have connected a Cavan or trailer if it is fitted with LED lights
You will know this as the car will not ask in the info screen have you connected a trailer etc,
Plus when turning the dash will not flash a picture of a green trailer.
This means the LED lights on your trailer, or carvan dont draw enough current to let the car know it is connected.
This will means your car is not set up for safety items like sway control
emergency braking with the trailer
or transmition shifting with the trailer.
To solve this I have just fitted a great product
LED Tow Connect - Tow LED Fitted Trailers Safely
Powered by Blogger.
Tow safely using this user-friendly vehicle to trailer LED light adapter module. This portable and durable pulse shunt module will help your vehicle 'know' a trailer is attached.
Discovery 3
LED towing pulse shunt for Discovery 3
$239
$239
Discovery 4
LED towing pulse shunt for Discovery 4
$239
$239
Freelander 2
LED towing pulse shunt for Freelander 2
$239
$239
RR Sport (pre 2010)
LED towing pulse shunt for Range Rover Sport
$239
$239
RR Sport (2010 to 2013)
$239
$239
RR Sport (late 2013+)
$239
$239
RR Vogue (2005+)
$239
$239
RR Evoque
LED towing pulse shunt for Range Rover Evoque
$239
$239
Audi Q7
LED towing pulse shunt for Audi Q7
$239
$239
Mercedes ML/GL
LED towing pulse shunt for Mercedes ML & GL
$239
$239
Porsche Cayenne
LED towing pulse shunt for Porsche Cayenne
$239
$239
VW Touareg
LED towing pulse shunt for VW Touareg
$239
$239
VW Amarok
LED towing pulse shunt for VW Amarok
$239
$239
BMW X5/X6
LED towing pulse shunt for X5 X6
$239
$239
Volvo XC90
LED towing pulse shunt for Volvo XC90
$239
$239
Mazda BT50 (2011+)
LED towing pulse shunt for Mazda BT50
$239
$239
Ford Ranger (2011+)
LED towing pulse shunt for Ford Ranger
$239
$239
Select Your Vehicle
Audi Q7
BMW X5/X6
Discovery 3
Discovery 4
Ford Ranger (2011+)
Freelander 2
Mazda BT50 (2011+)
Mercedes ML/GL
Porsche Cayenne
RR Evoque
RR Sport (pre 2010)
RR Vogue (2005+)
Volvo XC90
VW Amarok
VW Touareg
Quick Links
Home
Why do I need a towing module?
Payment/Shipping/Returns
About Us
Development History
Wholesale
LED Tow Connect - towing LED pulse shunt
I hope this helps out with your pride and joy and stay safe towing.
Post #346783 9th Sep 2015 2:12am
All you need is a few 50 ohh resistors like these
Put them in parallel between each light circuit & ground & you're done Thumbs Up
Post #346899 9th Sep 2015 6:53pm
jettec
Yes you are absolutely right the resistors will do the trick.
However I have fitted this shunt resistor module as it is just plug and play with your trailer or caravan.
As I do not have the tooling, time or training to mess with my cars wiring or the trailers wiring
Simples !
Post #346950 10th Sep 2015 12:57am
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
I've just had a tow bar fitted by the local Land Rover dealer and it works fine with my led lit caravan. The green indicator dash light works as designed
Post #347082 10th Sep 2015 6:08pm
