Home > Maintenance & Mods (L322) > Retrofit heated steering wheel? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
I can't see it being hard to retrofit the parts... Your biggest issue maybe changing the CCF... |
7th Sep 2015 8:41am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Are they not equipped with them as standard in Germany? I think HSE and above all have them as standard in the UK. |
7th Sep 2015 2:51pm |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
HSE doesn't have a heated steering wheel Zircon, at least not as standard.
8th Sep 2015 8:35am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35356 |
my 05 td6 HSE didnt have a heated steering wheel... ... - .- -.
8th Sep 2015 8:37am |
Must be Vogue and above then. |
8th Sep 2015 9:12am |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 |
My 2003 HSE has a heated steering wheel so yes it is possible.
11th Sep 2015 10:56am |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
The heated steering wheel is controlled buy a small Ecu under the airbag it's not just a switch and a power supply. Non heated steering wheel vehicles use the heated button to turn on the air circulation.
11th Sep 2015 4:50pm |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 |
You will need the slip ring cassette from a vogue as there are no connections in the one fitted to the HSE, also a relay which is fitted into the back of the fuse board in the glovebox and the switch pack on the steering wheel.
11th Sep 2015 9:10pm |
