![]() | Home > Technical (L322) > Howl under medium acceleration - 4.2 SC |
Very difficult to explain but when I accelerate I get a deep howling noise. throttle related, and also load, if I were to accelerate downhill it would be quiet, uphill it would be "normal" engine noise, but typically this happens on the flat, so probably 30% throttle.
Thanks - but it's too loud really to be Alt related. |
georgedb Member Since: 12 Apr 2015 Location: Gauteng Posts: 82 ![]() ![]() ![]() |
Hi there dan_uk_1984
The exhaust system is being replaced tomorrow. Not inc the cats initially, will report back tomorrow evening.
Replaced the exhaust - no change |
Sorry to hear Dan
Tried recording the noise but you cant really discern anything.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3155 ![]() ![]() ![]() |
Next time it's making the noise, try turning the air con off, my SC made a noise on partial throttle and when switching the air con off it stopped. I've got a new compressor here I just haven't got around to fitting it yet.
Thanks David - Double checked that on the way home, still the same though.
I spoke to Powerhouse about changing the pulley on my SC, they did mention that the bearings in the SC can occasionally give problems at around 100k. Apparently it's not that common though.
Thanks for that info David, I didn't appreciate that the charger would still turn...
I'd imagine it'll be turning a hell of a lot slower with just air turning it compared to what it would with the belt though.
This is doing my head in, the garages round here (Bude, Cornwall) are so utterly inept!
hongkongphooey Member Since: 26 Aug 2010 Location: Douglas. Posts: 227 ![]() ![]() |
Could it be a brittle belt howling/slipping on a pulley? There are quite a few in there. Present* 2006 Santorini SC Vogue SE.
