Home > Technical (L322) > Howl under medium acceleration - 4.2 SC |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Dan, have you checked for air leaks? Smoke tested it? Easy DIY job with a disco smoke machine!
22nd Oct 2015 8:21am |
Thanks for your replies guys!
22nd Oct 2015 7:57pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
Dan, my advice would be to remove the pollen air filter assembly and take the car for a drive as this will give you a clearer indication of the noise - I drove mine with that removed and what a difference in noise from the Supercharger !! You will need to remove the engine cover to take the pollen filter assembly out (quite easy)
24th Oct 2015 5:20am |
kyle h. Member Since: 15 Feb 2016 Location: West Virginia Posts: 23 |
Hi Dan, I believe I have a similar noise as you. I had read somewhere that there are numerous LR tech bulletins with various noises. Have you had a look through any of those?
15th Feb 2016 2:35pm |
Hi Kyle,
18th Feb 2016 3:00pm |
When driving today the noise was really noticeable, frustratingly you cant hear it at all on the dashcam:
18th Feb 2016 8:41pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35279 |
just a thought Dan, why not spray wd40/water/something on each of the pulleys and see if the noise goes away when you rev. ... - .- -.
18th Feb 2016 9:49pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
+1 same here air con |
19th Feb 2016 2:12pm |
Sorry should have updated, all new belts, pulleys and idlers a couple of weeks ago. |
20th Feb 2016 2:05pm |
Did that fix it?
22nd Mar 2016 12:06am |
bluebattery Member Since: 04 Apr 2016 Location: London Posts: 21 |
Hi Dan,
14th Feb 2017 10:36pm |
Sam,
15th Feb 2017 1:57pm |
