![]() | Home > Technical (L322) > Another trans fail safe question.. |
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 ![]() ![]() ![]() |
Could be the selector switch on the side of the box I think there is something in the wiki about it or do a search which should bring loads up about it |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
Hi, how easy is this switch to get at? are they serviceable or just replace? thanks |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
Access is easy, getting them off a bit of a faf... pretty sure they are sealed units, they are rather expensive though, many hundreds... eBay is probably a good idea... you need to get it confirmed it is faulty first, needs some diagnostics... Pete
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
Hi guys. Just to point out that if JPS has a TD6 then unfortunately the inhibitor switch is inside the sump rather than bolted to the outside of the casing
Can always count on RRPhil to put us right |
