Home > In Car Electronics (L322) > Light control module reconditioning
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
I've had a fast flashing drivers side indicator for a few weeks , full set of new bulbs did nothing also checked all the connections etc with no joy, so today removed the LCM and found what you see in the pics below.
Now my question is does anyone know of a decent place that might be able to refurb it , the chip in the picture has lost one pin to rust , I've cleaned the board as best I could with contact spray cleaner but it still gives the same problem of fast drivers indicator . Everything else works fine . As a last resort before binning it and forking out the ridiculous amount for a new one I would change the chip myself , but would prefer an expert to have a look first , any ideas much appreciated .
Post #342988 17th Aug 2015 5:54pm
You could try these people...
http://www.bba-reman.com/uk/index.aspx Pete
Post #342990 17th Aug 2015 6:00pm
Zirconblue
i've been to BBA reman, very professional operation. Had them sort out a comms 2000 unit on a Citroen for me.
Post #342993 17th Aug 2015 6:12pm
birchyman71
Cheers I've emailed them for some advice .
Post #342998 17th Aug 2015 6:24pm
RaveRover
Australia 2005 Range Rover HSE 4.4 V8 Java Black
Hey, just a question from left field.. looking to see if I can use an LCM from a BMW E39 in my 2004 L322.. the Units themselves are virtually identical.. Both 'LCMIII', both the same shape and size. Same plug orientation. I ask because the BMW lear LCMIII seems to be a lot more readily available.. and cheaper. anyone tried this? Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
1986 RRC Highline with offroad mods. Arctic Silver
2001 P38 HSE. Ardeness Green.
1995 RRC soft dash (beautiful car) Green.
2005 L322 HSE V8. - Current, most awesome car yet. And most expensive.
Post #581877 31st Jan 2021 10:57am
