Home > Maintenance & Mods (L322) > Brake pad and disc set for L322 2002 4.4 V8
Dolphinboy
@andy B.
Make sure the replacement water pump is oem/Hellas - first line and any other are Censored
Have had 2 first ,one go on em but all good with the new Hellas one. Thumbs Up
Post #342764 16th Aug 2015 2:56pm
Andy B
^ Cheers for the tip DB, but I have chickened out doing this myself this time as I am in the middle of trying to move house, so the car is at the MD at the moment.....cheap as chips...not Sad Sad Mind you much cheaper than the quote to replace the brakes and pads all round......£1400!! Shocked Shocked SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #342766 16th Aug 2015 3:02pm
Zirconblue
From what i've seen the cooling systems on the BMW units are prone to failure with just about every component - and if you use cheap pattern parts it's even worse!
Post #342819 16th Aug 2015 7:30pm
