![]() | Home > Maintenance & Mods (L322) > EGR cleaner |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
I picked up a can of this from halfaurds the other day for �10, I gave it a go following the instructions on the tin and the car is a lot more responsive now just wondered if anyone else has tried this
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I used one of these, as they are not needed to meet UK emissions,
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 353 ![]() ![]() ![]() |
I've bought a can of this stuff, is it really as easy as it says on the tin? |
Lego Member Since: 01 Jul 2015 Location: Suffolk Posts: 12 ![]() ![]() ![]() |
I, as many driving the TD6 have bought an EGR Blanking Kit (tube) my came from a BMW kit supplier for �24 and was aircraft grade quality materials and finish, I fitted it with a new Green cotton air filter and changed the crankcase breather filter also, the jobs took about 2 hours but I had encroached into darkness so holding torch added time.
^^ Wot he said!, Welcome Paul
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Blanking off the EGR is good, but it's worth putting a dose of EGR cleaner trough it afterwards as the inlet tract will still be bunged up with historic gunk. It's effectively intake cleaner.
Mines a 70000 mile v8 so hopefully it wasn't too bad it certainly made a difference ,as for stripping it down to clean out the inlets that will be a long process and only happen if performance really drops off ,looking at the wiki for replacing the egr it's not a ten minute job |
For the TD6 it's about a 30 - 40 minute job, for the TDV8 I have no idea |
