Home > General (L405) > Seat belt clasp rubbing against leather?
EdJ
My L405 has been pretty faultless since I got it about 6 weeks ago, but there is one thing that is a bit annoying. The driver's seat belt clasp rubs against the leather seat, and when the road is even slightly bumpy, it squeaks a lot.
Has anyone else noticed this? The passenger one is fine and I can't see any difference between them. I've noticed in previous cars that there is usually some velvet on the clasp that stops this from happening, but not on the Range Rover. 2024 Range Rover P550e AB
Post #341698 10th Aug 2015 6:30pm
dfulgo
Italy
Yes, I've already read about it but can't remember where. Try a search with multiple keywords, i. e. Belt Rubbing Seat.
Post #341712 10th Aug 2015 7:14pm
Doodle
Sounds uncomfortable.
Does it feel over-tight when fastened or conversely, not tooooo much tension?
What about the height adjustment?
Otherwise try that special cream the cyclists use for too much chaffing of the nethers.
Hope it's not something going around all L405's. Shocked
Rolling with laughter
Post #341714 10th Aug 2015 7:27pm
CS
My 322 (2012) has the velvet type material on the seat belts so your dealer ought to be able to supply/fit this. Only Range Rovers since 1988
Post #341720 10th Aug 2015 8:31pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Had this on my L322, bought a roll of self adhesive hook & loop from Ebay for about a quid and stuck a strip of the loop side onto the seatbelt receiver where it rubs on the seat piping, now its totally silent.
Post #341721 10th Aug 2015 8:35pm
