Home > General (L405) > Where can I find an ignition switched 12v supply?
Hobo729
Cyprus 2019 Range Rover Autobiography SDV8 Baltic Blue
I have just bought myself a concealed radar detector (Snooper) and fitted behind the front grill - easy.
However, has anyone got any idea where I can connect into an ignition switched 12v supply in the engine bay - I can't find anything that looks easy. Question Idea Neutral
Post #340444 2nd Aug 2015 5:26pm
there should be an ignition live in the headlight wiring, i have a drl switch patched into mine... ... - .- -.
Post #340447 2nd Aug 2015 5:36pm
Hobo729
Wiring
Thanks Stan - that is a relief and very conveniently located too. The offside headlight is preferred and mine are adaptive units - can you tell me which colour cable is the ignition switched connection? I have run a multimeter over the pins in the headlamp connection plug and several seem to have 12v with no ignition or lights on - very odd.
Post #340709 4th Aug 2015 12:14pm
