![]() | Home > Wheels & Tyres > Will Disco 3 18" wheels fit my 2004 L322? |
Both wheels have the same PCD, Offset, Centre Bore Diameter and Mounting bolt size so it appears the answer to your question is, yes they will fit.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
^^ there are 2 different sizes of wheel nut, the early L322 use a 20mm wide nut and the later ones use I believe 23.5mm. I am not sure as to the size that the Disco uses, but the wheel nut should be a snug fit in the hole in the wheel. All wheel nuts are the same thread for the L322 and D3/D4, best way of telling is to offer one of your nuts up and see if it's a loose fit |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Same nuts as the later-type FF on the D3/4 and RRS. |
DaveAngel Member Since: 15 Aug 2011 Location: Cowplain, UK Posts: 205 ![]() ![]() |
I have a set of disco 18" which o've got mud/snow tired on. Used them a couple of years ago on my l322 over winter with no problem. The over all diameter is a tad smaller so check your speedo, but should be fine. __________________
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8683 ![]() ![]() ![]() |
Size should be roughly the same 255 60 18 is the standard 18" disco size which is the same as the ones needed on the ffrr 18" wheels. There is nothing that can't be fixed with a hammer😜😜
255/60/18 is standard on the early ffrr, 255/55/19 is the later size, and I believe that 255/50/20 is the SC ffrr size. all have the same rolling diameter, give or take a fraction of a %. The only difference is the size of wheel nut, early had 20 mm diameter wheel nuts and the later ones have 23.mm diameter wheel nuts to bring them in line with the Disco's and Sport's, and moves them away from BMW sizes. Which is strange as they have kept the same size hub, so you can still fit Beamer wheels |
