![]() | Home > Technical (L322) > Price of turbos and fitting via an indie |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
Might be a split hose Got - 2017 SDV8 Autobiography in Loire Blue
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
Check the hoses, as said as you look at the engine the one which tends to go is the one on the top right
DaWalley Member Since: 24 Jan 2013 Location: Cheshire Posts: 42 ![]() ![]() ![]() |
Thanks guys. I know what you mean re the hoses. I had one replaced a few months ago but can't recall which one.
It might depend on which hose and the size of the split? Got - 2017 SDV8 Autobiography in Loire Blue
There is a complete silicon hose set available for the TDV8, if it is a split hose, I suggest to replace the complete set as those silicon hoses are very strong. There is a post on here about the hose sets |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
it might not even be split, it might have just popped off and needs pushing back on and the jubilee clip tightening up |
neal Member Since: 22 Jul 2015 Location: collingham west yorkshire Posts: 1 ![]() ![]() ![]() |
I have 2011 4.4v8 which has just started smoking on acceleration. My indie guy says 25 hours labour which he has agreed at £1500 and if its seals then £375 or if its the turbo complete then £1500 inc vat. |
^has yours had the turbo drain modification done? There was a service bulletin re smoke on acceleration which involves fitting a scavenger pipe to one of the turbos. Not sure if it would be done foc at a dealer but it is worth asking the question! There is nothing that can't be fixed with a hammer😜😜
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 186 ![]() ![]() ![]() |
http://www.fullfatrr.com/forum/topic29786.html Mine was smoking under acceleration. Dealer carried out the drain mod and solved the problem. |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
With a poink/clocnk.....
