Home > Technical (L322) > How to get windows out
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Am changing my regulator on my rear offside window as the window has become jerky and will probably go soon.
Have got everything off including door card etc and the 2 lower bolts that attach the window to the regulator. But can't get the window low enough to get the upper bolt out (the glass is in the way)
Anyone got any guidance or experience doing this?
Thanks
Post #336880 11th Jul 2015 3:01pm
when i did my front, i only had to undo the 2 lower bolts and then twist the glass at an angle to get it out..should be the same for the rear i think.. ... - .- -.
Post #336900 11th Jul 2015 5:13pm
v8rich
England 2002 Range Rover HSE Td6 Bonatti Grey
Stan, were the fronts that easy? I've got two to replace in mine, and I've been putting it off as I've not been able to read up on it. Any pointers would be helpful please
Post #336906 11th Jul 2015 6:11pm
not easy but with a bit of fiddling can be done.. ... - .- -.
Post #336929 11th Jul 2015 8:30pm
Dolphinboy
Right, still no joy on getting the rear offside glass window out. Have got it down to the bottom of the door as far as it will go but it rests on the wheel arch indentation and is still some 6" too high to access the upper bolt.
Is it a LR Dealer job only or does all the gibbons around the window space have to come Out to DIY?
Any help or steerage towards a guide/diagram would be fab
Ps have found the fault - it's a little restraining cap for the wire end which has cracked and is not holding the wire in - it is made of plastic for god's sake whilst everything else is metal! Evil or Very Mad
Post #338012 19th Jul 2015 5:43pm
Here you go...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #338021 19th Jul 2015 6:39pm
Dolphinboy
Thanks hay man! Hope your old girl going strong! )Reckon they must have loved our coloured ones the most and so made them better!) Rolling with laughter
Post #338064 19th Jul 2015 9:14pm
