Home > Maintenance & Mods (L322) > How accurate is the average MPG?
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
I do the same journey most days , 100 miles round trip with 80% being motorway miles
I use the adaptive cruise set at no more than 70 but as it's always rush hour I'm usually cruising at 50 mph
The average for each journey on the trip computer has been 40-41mpg.
Is this accurate? If so I'm very impressed as my D4 only gave me 25 ish MPG.
Mine is a 4.4 TDV8 CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #334104 23rd Jun 2015 5:06pm
I think they are always a bit optimistic, mine says around 18 but I get closer to 15...
Does sound good though.... Pete
Post #334106 23rd Jun 2015 5:24pm
I meant your MPG sounds good... not my 4.4V8 petrol... but it does sound good BTW.... Rolling with laughter Pete
Post #334107 23rd Jun 2015 5:26pm
RiccartonRR
Haylands Rolling with laughter Rolling with laughter Thumbs Up
My 3.6 TDV8 gives me an average of 19 so I'd say it's bloomin good Big Cry
Either way, if you take optimism into account it's still better than your Disco Thumbs Up Thumbs Up
Post #334135 23rd Jun 2015 8:13pm
Rangeyman
If you are cruising at 50 it could be your optimum mpg,sounds good figures to me.To actually put a spanner in the works ,most speedos are inaccurate unless they are calibrated meaning the mileage is not right and neither will the mpg.If you want to be accuratel log exactly what you put in at the pump in litres[on your receipt] you can then measure what distance you do un a map but probably unfeasible.You could check your distance covered on a measured mile that you can calculate the distance difference then giving an accurate Mpg!!!
Post #334137 23rd Jun 2015 8:24pm
Vogue Owner
I think I'll stick with the feelgood factor of 40mpg! CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #334138 23rd Jun 2015 8:31pm
Zirconblue
it all depends how accurate your speedo is, and that can be affected by worn tyres vs. new ones.
The actual amount of fuel consumed by the engine should be fairly accurate, but it depends the speedo for the mileage part. You can of course use a GPS to measure your distance and fill the tank up, drive a bit then fill the tank again and work it out manually, but even filling the tank like that is hardly an exact science. And if you have a fuel burning heater that'll use some too in winter.
I reckon the computer is as near as accurate as you'll need it to be.
Post #334167 23rd Jun 2015 10:55pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
mine over reads by 10% (3.6) Cheers
James
Post #334216 24th Jun 2015 1:26pm
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
4.4 TDV8.
Mine is consistently over-optimistic by 3mpg measured against computer reading vs tank fill/odometer method.
Real time mpg for mainly motorway miles at 70-75mph on cruise control over the past 7000 miles has been 27mpg which is reasonable for a 3 tonne 300+bhp bus!
Post #334532 26th Jun 2015 12:45pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
getting 14mpg currently on my 4.4V8 gasoline 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #335318 30th Jun 2015 6:15pm
Zirconblue
Bear in mind though that filling the tank and using the odometer, doesn't take into account idling, sitting a traffic lights etc. The computer stops recording fuel consumption when the vehicle stops moving. So it will always be slightly higher than the filling the tank method.
Post #335356 30th Jun 2015 9:06pm
sako243
What is your source for that comment? Just curious since I have never come across anything like that. In fact when I was up in the mountains at my grandparents in the Highlands the on board was dropping whilst we were stationary watching a lek going on... Ed
Post #335367 30th Jun 2015 10:03pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
I just started playing with the consumption computer. I was able to see it hit 20.8 MPG(US). All I need to maintain that is a slight grade downhill at 35 MPH. 4 mile trip average was 17.6. I'm optimistic I'll hit 24mpg highway. I also play the lottery.
Post #335374 1st Jul 2015 1:05am
supershuttle
I Find the indicated mpg useful as a diagnostic tool rather than an accurate measure of fuel consumption, for example when the caliper was sticking on my last car the average mpg got worse which prompted the investigation and discovery of a very hot wheel.
FWIW I use the distance to empty more, a full tank is generally about 420 miles and one or two weeks later it's zero, meaning a trip to the filling station is required. Geoff
Post #335376 1st Jul 2015 6:12am
Zirconblue
To be honest i've not looked that closely at the one on the range rover, but on previous cars with econometers it does seem to have stopped recording when stationary. If i remember correctly on a Citroen the 'actual MPG' display would show dashes pretty much as soon as you stopped.
As said above though, measuring MPG is a good diagnostic tool, whether you use the computer or full tank against mileage driven. Neither are exactly under laboratory conditions.
Post #335461 1st Jul 2015 9:04pm
