![]() | Home > Technical (L322) > FFRR MY07 - HVAC unit not shutting down, not FSR |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
That's weird, probably points to something up with the BECM then... maybe....?? Pete
Mrmerlin Member Since: 21 Mar 2013 Location: Aurora Colorado USA Posts: 13 ![]() ![]() |
FWIW I would also keep an eye on the cargo hatch lights,
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
Thanks all for the suggestions! I've currently not found The Fault. I don't think it is the hatch door lights, these seems to be off when closing the hatch.
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
I also have had this issue on and off. I am beginning to think my problem is the RF receiver for the key waking the BECM
I've now «settled down» with the following temporary solution:
I can only say that it is easy to ignore the issue. Fundamentally a lot of RR go around with half charged batteries the voltage of a fully charged battery should be 12.75v mine is regularly below this after a long run. My advice would be to fully charge your battery with at least a 4A charger overnight , trickle chargers do not work on these cars, and then have it tested for capacity.
