Home > Advanced Factors > L322 Vogue 2003 TD6 FULL service parts needed
antonio3z
Italy 2003 Range Rover Vogue Td6 Adriatic Blue
Dear Advanced Factor Parts,
I'm seeking for the following parts:
- Oil filter and washer
- Air filter
- Fuel filter
- Air cond. Pollen filter
- Cam Breather Filter
- Both front wiper blades
- Front brake disks and pads + sensor
- Front anti-roll bar links set
- Front suspension arm set with ball joints (both lower and upper arms)
- Both white clear side indicatos
- 2x Xenon headlight buld
- Passenger side mirror
if available at reasonable cost due to shipment weight increase:
- Both differential oils
- Transfer box oil
What the shipment to Italy is going to cost?
Thanks a lot for the support,
Cheers,
Antonio
Post #331486 8th Jun 2015 8:56am
