Home > Duckworth Parts > L322 Vogue 2003 TD6 FULL service parts needed
antonio3z
Italy 2003 Range Rover Vogue Td6 Adriatic Blue
Dear Duckworth Parts,
I'm seeking for the following parts:
- Oil filter and washer
- Air filter
- Fuel filter
- Air cond. Pollen filter
- Cam Breather Filter
- Both front wiper blades
- Front brake disks and pads + sensor
- Front anti-roll bar links set
- Front suspension arm set with ball joints (both lower and upper arms)
- Both white clear side indicatos
- 2x Xenon headlight buld
- Passenger side mirror
if available at reasonable cost due to shipment weight increase:
- Both differential oils
- Transfer box oil
What the shipment to Italy is going to cost?
Thanks a lot for the support,
Cheers,
Antonio
[/list]
Post #331484 8th Jun 2015 8:54am
duckworthparts
Site Sponsor
Hi
all prices below are for genuine parts unless otherwise stated and all excluding vat
- Oil filter and washer �13.44+VAT
- Air filter �27.85+
- Fuel filter �34.74+
- Air cond. Pollen filter �27.85+
- Cam Breather Filter �22.48
- Both front wiper blades, PAIR �27.57+
Brake pads �59.08+
pair of discs �153.00+
sensor �16.43+
- Front anti-roll bar links set, pair of �42.05+
Delphi upper arms pair �120.00+
Delphi lower arms pair �90.00+
- Both white clear side indicatos pair of �36.31+
Genuine �135.00+ each
Non genuine �68.00+ each
- Passenger side mirror - chromatic or non chromatic? just the glass or complete mirror assembly? PM me full VIN
- Both differential oils �17.00+ per litre
- Transfer box oil �11.00+ per litre
Postage �38.00+Vat possibly less if discs and pads were removed due to weight
Cheers
Dan You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #331503 8th Jun 2015 10:26am
antonio3z
Thanks a lot for your reply.
I'll let you know my VIN as soon as I go back home. I want a chromatic one, with the plastic assembly part behind, at the moment the old owner just glued a piece of a non automotive glass mirror over the previous assemly part. Not easy to explain, I might send a picture.
Post #331524 8th Jun 2015 1:05pm
duckworthparts
Site Sponsor
Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Post #331533 8th Jun 2015 2:45pm
