Home > Technical (L322) > Air suspention fault help would be appreciated.
texpis
England 2002 Range Rover HSE 4.4 V8 Alveston Red
I know this has probably been done to death but I couldn't find my fault. Car is a L322 4.4 petrol 2002.
I put the car in high suspention mode it took a long time to get up there but eventually it did, when I put it back to standard the front went down the back stayed up. I have a hawk eye diagnostic, so I checked for faults and none are recorded, I deflated the tank hoping this would reset and now it's stuck on the bump stops. The pressure in the system is saying 10 bar still no fault codes compressor seems to be starting up and is not over hot 60 degs.
So what do I look for any assistance would be gratefully received.
Mick
Post #331240 6th Jun 2015 10:46am
height sensor or this http://www.fullfatrr.com/forum/topic23038.html ... - .- -.
Post #331247 6th Jun 2015 12:38pm
texpis
Ha thanks for the reply Stan flipping great hole in the front air bag trust me to look too deep ah well where's the best place for front air bags
Mick
Post #331249 6th Jun 2015 12:45pm
dan @ duckworths...do a search there's loads on what types and how to fit etc.. ... - .- -.
Post #331250 6th Jun 2015 12:46pm
texpis
There's a Delphi one on eBay £175 sounds good what do you recon?
Mick
Post #331252 6th Jun 2015 12:51pm
Best to change struts & bags over in pairs Thumbs Up
As you have a MY02 and if you are on original bags this is definitely recommended.
Someone will buy your "good" strut on eBay so you can recoup some of the cost Smile .
Post #331267 6th Jun 2015 2:09pm
texpis
The right hand side was change just before I acquired it and there has been no problem so prob going to replace the damaged one and see how it goes thanks for the advice.
Mick
Post #331277 6th Jun 2015 3:16pm
Thumbs Up .
Post #331291 6th Jun 2015 4:24pm
texpis
Okay decided to change both bags and maybe all 4 are the rears as prone to rot as the front ones? Should I replace them?
Mick
Post #331439 7th Jun 2015 9:23pm
jambo27
Have a look at the rear ones and see how they look - although it can be hard to tell because they sometimes show very little signs of wear.
Sensible option is to replace everything and then you know what you have got - ie 4 brand new bags and no worries for long time but there is a cost factor to consider for 4 bags and also the rear ones are just a bag and not a bag/strut combo so I am not sure if you should also change the struts on the back if you change the bag. Also on this point the front is a relatively quick job (1hr) as everything is contained in one part - the rear is a lot more involved as you have to take a lot more of the suspension apart to get to the bag.
If costs are not so much of an issue and you did go down replacing all the bags I would also be tempted to consider replacing the height sensors as well. 2008 TDV8
Post #331463 8th Jun 2015 6:34am
