![]() | Home > LPG > Lpg Thoughts/advice please |
devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 348 ![]() ![]() ![]() |
Afternoon chaps |
Jambo27 many thanks for your help |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I think too, you can only used LPG once the engine is up to normal operating temperature. So if like me you only do a 15 min commute, you'll probably find you'd only use LPG on long trips. I decided not to bother with one as I just wouldn't get the use out of it and added to that you can't travel with Eurotunnel with an LPG powered vehicle.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8498 ![]() ![]() ![]() |
You can't go wrong with LPG, had numerous cars with it, that BMW 4.4 is fine running on it..
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I have same car, same mileage with lpg, -and same colour! yes to all above posts. there are better makes of lpg, just make sure it has the LPG certificate, more importantly, make sure there is the service history file, read through it. the big things to consider looking out for in this history, are the gearbox, hopefully replaced, note the mileage. (£2000 job) and at this milage, the engine camshaft chain guides have a limited life. hopefully they are done too. buy a new battery for it. £120. then you are in for a bosch 5 yr guarantee etc.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1364 ![]() ![]() |
That looks like a bargain to me at 5k |
Thanks gents |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
As said a couple of posts back. Takes less than a mile to switch to LPG even on the of coldest days. If it has a certificate it can be registered as a dual fuel vehicle, which saves you on road tax.. Don't get too excited, it's only £10 cheaper ![]() It used to be free for LPG vehicles to drive in the london congestion zone but Boris stopped that in 2012. But LPG vehicles are exempt from the strict london low emission zone. |
Swithins Member Since: 22 Oct 2013 Location: West Malling Posts: 151 ![]() ![]() ![]() |
I run two cars on lpg, a 4.2sc FFRR and a 1999 SL500. I use the SL to commute to the station 12 miles away, and although it takes longer to switch over in winter its done within a couple of miles. The SL had it fitted when I bought the car and was so impressed with it, and the amount of garages that actually supply the fuel as well, I fitted the same system, BRC, to the FFRR when I bought it last year. I have driven 20k in the last 14 months an believe that I paid for the LPG conversion months ago. At my local station I pay 59.9p for lpg while the diesel drivers are putting up with 120.9p, he he he |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
I am interested to know when you got the LPG conversion done on the 4.2 SC did you get the autolube?
Any engine can be made to run on LPG, it is pretty easy to convert a car and there are lots of so called experts out there doing it, there is a list of engines supplied by the LPGA that require the flashlube, the Jag engines are on the list. if the conversion has been done correctly and been set up properly then there is no reason for it not to last the lifetime of the car.
I took all the advice from this board and from the fitter who services the lpg on my merc and had the autolub fitted. That was over a year ago and I have topped it up slightly only once in 20,000 miles. I have the brc system in both cars and swear by it. In the first few weeks I had a few teething problems but since then no problems at all. I paid 48p a litre the other week, so a full tank of 75 litres cost me just £36 and I get around 244 miles of mixed driving for that £36. I too spent a long time looking at if it was a hassle converting a RR and with my experience of the merc it seems the doom mongers have either fitted a cheap system so had problems, gone to a dodgy fitter and had problems or are the worst kind, so called purists. Now I don't put low profiles on a 4x4 it isn't lowered or had an aftermarket kit on it, that's where I may be a purist, but complaining about a fuel??. I run my own business and spend money to be tax efficient. That is how I see the cost to convert the RR, I'm now tax efficient with my cars as well. I can also fully enjoy the car and am not stuck permanently in the driving lane at 60mph trying to squeeze every mile out of my fuel. I love the sound of the v8 and enjoy the dropped jaws as I effortlessly glide past most as my lead right foot buries itself into the plush carpet. What's the point in having a supercharger if you don't make it work hard now and again. One you have owned an lpg converted car with a large thirsty engine you will find it hard to own anything else, and now I would assume they are more appealing than their soon to be taxed out of site diesel cousins. Current:
I'd get the flashlube looked at, you should have used more than that in 20,000 miles.... |
