![]() | Home > Technical (L322) > axle articulation validity fault |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Possibly reversed one of the height sensors. Have a search on here there are a few threads on it, they can get over extended and basically flipped over.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8547 ![]() ![]() ![]() |
What he said....^^^ |
DoverVogue Member Since: 14 Apr 2014 Location: Dover Kent Posts: 4 ![]() ![]() |
Thanks, ive had it in the air before with no prolems but I'll take a look tomorrow evening in the light and see if ones been knocked off or something. |
N/s/r sensor has a snapped arm. New one it is then |
Quick fix if you need to use it.. take the old arm off, use a metal coat hanger and make a rod with loops at the end that is the same length as the original, make the loops slightly larger than the end of the nipples that locate it, put the new rod on and slightly flatten the loops with a pair of pliers to stop it falling off.... job done... Pete
I'll keep that in mind if I get stuck. I always have cable ties and gaffer tape handy just in case! |
Guess it depends on which bit of arm has snapped, the metal bit or the plastic bit?
ammar Member Since: 10 Jun 2018 Location: Bedford Posts: 9 ![]() ![]() ![]() |
Hi,
