Home > Technical (L322) > AMK Compressor Troubleshooting?
brucebaner1
United States 2006 Range Rover HSE 4.4 V8 Alaska White
I have a 2006 Range Rover and I did an overhaul of my suspension system. I installed a new AMK compressor with relay, 2 Height sensors (front), 2 Struts/bags and 2 stabilizer bars. I got stuck doing rust repair/battery replacement/passive start/window regulator so the project took a little than expected. I remembered reading on here that you must not lower the car until you fill the bags up with air. Do you need to have the tires on to test the bags? I don't notice a considerable difference in the bag size when I squeeze them.
Also, the compressor at start is REALLY loud. I hear a hissing sound and feel some cold air by the black and black fittings on the right hand hand side. I also received a warning on the dash that the car will lower when the system cools down. I've never seen that message before. I will say the compressor is pretty hot to the touch.
Do I need to tighten the fittings? Can I break something if I tighten them too much? What other troubleshooting should I do? Lastly I purchased the IID Tool, can this help?
Thanks in advance!
Tim
Post #329434 26th May 2015 12:15am
You should have disabled the system with the IID tool before you changed the bags, you then re-enable it. You have to have it on the ground to fill it with air, if it senses that it's got it's wheels off the floor it won't do anything, you can lower it until the wheels are at about the right height and then refill it....
You shouldn't feel any air leaks around the compressor unless it is letting air out of the system, the fittings are metal/plastic and have a low torque figure for tightening so don't go too mad, maybe better removing the fitting and check it is OK? do not remove the metal fitting from the ends of the pipes as it can damage the pipe and cause leaks. I think the pump fittings are all pushfit though, there should be a white ring on the pipe that shows when it is pushed in enough...
The loud sound could be because it is pumping to a leak, it needs a bit of back pressure to slow them down a bit...
Read the manual for the IID tool, there are lots of things you can check, including the temp of the compressor and the pressure in the air tank.. Pete
Post #329457 26th May 2015 9:39am
brucebaner1
Thanks Pete! I will tighten and review the IID tool. Will the bags be noticeably filled with air?
Post #329480 26th May 2015 2:17pm
If they have air in them they will be virtually solid, very difficult to flex them with your thumb... Pete
Post #329498 26th May 2015 4:47pm
brucebaner1
So I reflashed the AMK ecu last night (using IID tool), started the truck tonight and the compressor is not starting. Do I need to do something similar to a hard reboot of a computer?
Post #329728 28th May 2015 2:37am
It should just work, check the plug is properly home, then check if it has power to it, start the car, press the suspension up button, this should turn the pump on, then check if it has power to it on the thick red/white wire, if no power then it could be fuse 18 in the boot, 50amp or the relay that lives there as well...
Also may need to re-enable the EAS with the IID... Pete
Post #329733 28th May 2015 7:35am
brucebaner1
Thanks again; I will try these things tonight. I also research something about a hard restart of the battery. Fingers crossed!!
Post #329878 28th May 2015 10:33pm
brucebaner1
I rechecked everything and reflashed. No difference. I even tried the battery reset (I think.....). BUT I did notice my wife must have accidentally lowered the truck. I noticed my tires seem to be touching the floor. I know I've heard from many resources that the car should not be lowered prior to the bags being filled with air. Since my compressor is not working, my bags are not filled with air. Do you think lowering the Range caused a problem? I also checked fuse 18; no issue with the fuse.
Post #330126 30th May 2015 10:13pm
mike whiskey
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Have you got all the doors shut when you wait for it to fill? The system is inhibited when doors are open to prevent the car moving as passengers are entering or exiting.
I think this includes the tailgate, so if you are standing at the back wondering why there is no life.....
Post #330396 1st Jun 2015 11:24am
It's only the doors, not either bit of the boot!! Pete
Post #330409 1st Jun 2015 1:51pm
