![]() | Home > LPG > Coolant change - does this disturb the LPG system? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8380 ![]() ![]() ![]() |
Just the normal procedure to change the coolant, it will self bleed fine on it's own...
Pete, would it be best to do that on petrol though? Doesn’t the water temp effect the gas/petrol turn over point? |
Don't think it will make much difference Craig, If converted properly (and most are these days) the take off for the vaporiser is teed from the heater pipes so that the water flows correctly, as the heater flow is not controlled by the thermostate it doesn't usually get an air lock unless the system has been mounted too high in the engine bay, Matt's look low enough so he shouldn't have any problem, it looks like he's also got twin vaporisers so it would work OK even if very cold... |
Thanks Pete, as you can gather i know little about LPG |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 ![]() ![]() ![]() |
Thanks chaps - so by sharing the heater water, the system will drain and refill as normal when the coolent is replaced carefully? (or is the heater system's water separated from the engine's water?) NW060
