Home > Maintenance & Mods (L322) > Headlamp jets not working
bazwd
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Hi
Neither of the headlamp jets on my 2006 Td6 is working. The windscreen washers are working fine. I checked the fuse and that's ok so can anyone suggest other areas to check, please? I assume that the motor on the headlamp washer pump has failed but I don't know how the washer system is configured or where to look.
All help greatly appreciated, as always.
Many thanks
Barry
Post #328921 21st May 2015 4:31pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
blockage rather than electrical
or pipe off somewhere? Cheers
James
Post #328923 21st May 2015 4:37pm
Zirconblue
If you find the washer bottle filler and look down below it with a torch you'll see the washer bottle. you might be able to get access to the plug on the head lamp washer motor by taking the wheel arch liner out. If you un plug it you should be able to test if there is 12v getting to the motor when someone switches the washers (nb the headlights also need to be on to make the headlamp washers work.)
Also worth checking is some cars the head lamp washers only fire every x number of times you use the screen washers, and only when the headlamps are on. On my Jaguar for example they only operate every 6th time the screen washers are used, and they are disabled when the washer fluid level is low (so that the screen wash is prioritised with the water that's left)
Post #328932 21st May 2015 5:41pm
bazwd
Thank you James and ZB. I'd read somewhere about the H/Ls having to be on, and the intermittent use, but have tried those and nothing's happening! I'll make some time this weekend to do some peering around for this washer and motor.
Best regards
Barry
Post #328967 21st May 2015 10:17pm
bazwd
BTW, I treated the old girl (113k miles) to an expensive detailing, cleaned alloys and new wheel nuts and locking nuts this week. She looks GREAT (except for the washers ... and the rear camera ... and the non-lifting steering wheel).
B
Post #328968 21st May 2015 10:20pm
