Home > Maintenance & Mods (L322) > Replace Roof Lining |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 |
Ed China does one on a P38 here:-
12th May 2015 7:26am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
i did a change on a RR classic a few years ago now. the thing you have to do, is do it where the roof lining already is, as you cant realistically move it in your car. and if its a dirty place, then you are very likely (at least with a fabric one, to get it dirty. and if its hot you will struggle (like i did!) if its windy, dont do it! you would be better having an assistant too. if your old one is good, it will sell. but they are hard to transport away!
12th May 2015 7:46am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35269 |
i cant remember actually ever looking at mine, might not even be there so i dont think its worth the hassle.. ... - .- -.
12th May 2015 8:18am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
I took mine out a couple of weeks back and recovered it, mine is a 2003 hse without sunroof. No dramas at all. On the front screen pillar trims you need to pop out the SRS badge to expose a screw, the front console light has two screws, the rear pops out to expose two screws under it. The rest is all visible to remove. The headshell then comes out from the rear. |
12th May 2015 8:31am |
Come for a ride in mine Stan. I notice the leather (and admire it wistfully) every time I get in. I only notice though because it's because it's so nice I think, but definitely worth the effort IMHO. |
12th May 2015 9:05am |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 |
What material did you use? I'm currently doing mine and have gotten as far as removing the headlining, stripping the old material and removing all the old foam backing / adhesive that was left behind. I bought some nova suede type material that has zero give or stretch so my plan was to buy genuine alcantara in charcoal (near black)
12th May 2015 9:34am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Using leather for the headlining does seem a bit extravagant. I mean don't get me wrong i like leather but you get much cheaper vinyls that look the same, they don't normally feel the same, but seeing as head lining isn't really something you touch and feel.
12th May 2015 11:06am |
Bunchy100 Member Since: 18 Oct 2014 Location: Milton Keynes Posts: 16 |
Thanks Guys,
12th May 2015 11:10am |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 |
If you don't fit it, let me know and ill buy it off ya.
12th May 2015 11:19am |
I picked up my cloth from ebay in Oz. The cloth is better than original but looks the same and a perfect match. Its a sandwhich of a backing sheet, foam then the facing material, 3mtrs cost $50. I was looking at elastic micro suede as an option for a similar cost from Aliexpress. |
12th May 2015 1:34pm |
KGX117 Member Since: 29 Apr 2024 Location: Los Angeles Posts: 2 |
Hi. Any update on this topic? I have a 2006 Range Rover L322 and would like to change it with a 2010 Ranger L322 Headliner.
29th Apr 2024 11:47pm |
