Home > Maintenance & Mods (L322) > [Wanted] Steel section |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3808 |
I am building a bike rack for my RR and need some steel as follows:
7th May 2015 7:09pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8243 |
I've got some 80 x 40 x 4mm box, plenty strong enough for a bike rack....
7th May 2015 7:28pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7939 |
Are you copying an existing design ? |
7th May 2015 8:03pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
50x50x5 What are you trying to hang on the back???????????????? A Harley? That is some heavy duty steel, Geoff, A Land Rover Chassis isn't even that thick, from memory they are 1/8" or 3.2mm. Yesterday I couldn't spell Engineer... Today I are one!
7th May 2015 9:41pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 610 |
I think the later Defenders might be even thinner I think... Ed |
7th May 2015 9:46pm |
That steel FYI is 7 KG per meter, by my reckoning your going to be as near as dam it on 50 KG by the time you've finished. Now bearing in mind that a ffrr has a trailer nose weight of 150 KG max, that will leave you a payload of 100 KG or 220 lbs. How heavy is the bike? Or are we talking push bikes, in which case just how many are you mounting on the back? Cos from where I'm looking you've either got a very light motorbike, or you've over engineered the push bike rack, unless your going for 10 of the blighters, which will make turning interesting due to the overhang Yesterday I couldn't spell Engineer... Today I are one!
7th May 2015 9:52pm |
The 50mmx50mm is just so it slides into the armature on the Westfalia, it was another engineer who suggested 5mm wall - you engineers need to sing from the same sheet so we none engineers have a chance. The Farmers drop hitch is SOLID 50mmx50mm. I won't be able to lift 50kg so I might need to rethink, it'll be 4 bikes by the way one of which is electric, Geoff |
7th May 2015 10:15pm |
As for the design question, its not copying anything just a main spar of the 50x50 plugged straight into the armature then some angle at each end to form effectively a double T with a piece of angle down each side for the tyres to sit on and then some uprights welded to the main central spar to tie the bikes to.
7th May 2015 10:21pm |
Geoff, you can half that thickness and still have something that will hold an elephant, and still be easy to weld. If you are an experienced welder then you can go thinner, but I wouldn't recommend thinner than 1.5 mm and you would have to insert a tube for the locking pin to go through, otherwise you run the risk of elongating the hole.
7th May 2015 11:56pm |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 |
I sat down and designed a 'plug and play tray' a few years ago but never got around to fabrication. I was only using 3.2mm wall thickness though.....
8th May 2015 5:59am |
Geoff, 5mm wall is strong enough to use as a lintel for holding up walls bud. Seriously, 3mm is plenty, or 1/8th in old money.
8th May 2015 7:20am |
I have a 4 bike MaxxRaxx that is surplus to requirements - it fits the farmers hitch not the swan neck
8th May 2015 8:14am |
I hear what all of you are saying regarding the tube wall, I'll use thinner
8th May 2015 9:20am |
Does it need to fit the armature ?
8th May 2015 10:10am |
