![]() | Home > For Sale & Wanted > Wanted,a set of 4or 5 20" rims |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
if its a frequency jammer then the remote to car signal will be blocked , thats no use to the thief...i have a frequency capture device which displays a two way radio frequency for instance but it wont display anything from my car remote, so you need a pretty well techy device that will do this..i frequent maplins most saturdays and i have never seen anything that will capture a car remotes frequency.. ... - .- -.
As i said scarey not 100% sure but it was on some programme about two weeks back, and only caught snippets of it due to (homework issues with a 12 year old ) ====================================
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 ![]() ![]() ![]() |
Thanks Vogue - Great post |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Wonder if these grabbers work on the 2010 RRS and D4 with their proximity operated system using a keycard in your wallet/pocket/handbag. I know there have been problems on some cars, but I also wonder how strong the transmissions are and if they can be picked up at say 4m form the car 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
what i have read suggests that the remotes we use today have a rolling random code data system which means every time you press the remote a different code is generated, so someone sitting close by captures your 'lock' code ,this would be useless to unlock the car as a new code would be required from the remote..theoretical it is possible to capture a code but it would take a long time to analyse and generate a code to unlock the car...
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3765 ![]() ![]() |
Scarey, yes thats right, LR have fitted these for quite a while - and I and others had every confidence in them |
it would be very interesting to know how the thiefs did it.. ... - .- -.
Not Range rovers but interesting all the same ........ watch each youtube clip .......
seems a bit of a joke MICK, all can be explained by someone standing out of camera shot with the proper remote key.. ... - .- -.
Never thought of that scarey |
more thoughts on this one ..if the thief does get an unlock code for the door or 'jams' it so the driver thinks he has locked the car but hasn't , the thief will still have to insert a key of some kind AND get the immobiliser code as well... ... - .- -.
I thought the immobiliser was activated when the locks operated so if the doors don't lock then no immobilization! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
the ignition key has a chip/transponder built in to it and the ignition barrel has a receiver in it and when you put the key into the ignition it sends a signal to the electronics of the car to allowing you to start the car..when you take the key out , the immobiliser is re-activated....it doesn't matter whether the doors are locked or not... ... - .- -.
pjb Member Since: 15 Feb 2010 Location: Sunny Oxon Posts: 244 ![]() ![]() |
Hi Scarey,
