Home > Maintenance & Mods (L322) > Passenger door wont open - Help appreciated
Rosco
Hi, have done a search but cant find same issue.
My front passenger door wont open with exterior or interior handle. Locks and unlocks OK just cant get the Censored open!
This did happen about 2 years ago for 2 months then miraculously cured itself. Any tips on what to look for and how to do it.
Cant really use it as SWMBO will not climb over into the seat and I am NOT having her sitting in the back with an empty passenger seat Rolling with laughter
Post #325067 30th Apr 2015 8:31am
Presumably the dead lock has stuck on! Latch fault!
Have you tried a battery reset? I would 3 or 4 times just to be sure! Then.......
Do a little dance to the latch gods hoping it opens one last time so you can change it otherwise it will be a case of ripping off your door card (often in chunks) then having to cut the latch locking plate above and below the latch to release the door!!!
Not easy I'm afraid sir and for anyone reading this thread in the future on the search facility? The first sign of these faults get the latch changed as its a simple replacement job... When stuck shut... Turns into a nightmare!
Post #325075 30th Apr 2015 8:58am
Rosco
Thanks Craig, that has cheered me up ! So the deadlock is separate to the button that goes up and down (my naivety).?
Will do the battery reset and then the dance!! and report back........ Thumbs Up
Post #325079 30th Apr 2015 9:25am
craig forgot to mention that when you do the dance ,you must be naked and covered in strawberry jam, and a video must be taken and posted on the forum... ... - .- -.
Post #325085 30th Apr 2015 9:33am
But you of all people know the forum rules on Naked Video's sir Whistle Whistle Whistle Laughing
Post #325089 30th Apr 2015 9:35am
but he will be covered in strawberry jam craig Wink ... - .- -.
Post #325091 30th Apr 2015 9:36am
Rosco
That would not be a pretty sight however in the interests of door opening it may have to be done Rolling with laughter
Post #325092 30th Apr 2015 9:36am
Laughing Laughing Laughing Thumbs Up Good points both Thumbs Up
Post #325093 30th Apr 2015 9:37am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
how did you go with the door RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #573617 21st Nov 2020 12:52am
Holy thread resurrection batman! Laughing Thumbs Up
Post #573619 21st Nov 2020 12:57am
mjdronfield
Rolling with laughter more than 5 years covered in strawberry jam.
What’s that thing you can do from the side of the door with the rear door open? Is that different, or have I got the doors mixed up? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #573634 21st Nov 2020 11:52am
Lancaster322
England 2007 Range Rover Vogue SE TDV8 Buckingham Blue
Battery reset (completely off for a few days) been tried but will retry - just in case.
Agree that destroying the door card seems like the most likely (er. least expensive) solution plus cutting the locking plate free.
The problem is inside the lock I reckon. there is a YouTube that shows a small plastic 'interlock' piece that probably needs a good lube!
Thanks for the nudity suggestions too Confused
Post #715395 2nd Apr 2025 10:37am
