Home > Technical (L322) > Bizarre steering wheel wobble |
jke11y Member Since: 21 Jul 2009 Location: West London Posts: 32 |
My 2007 tdv8 has done this twice now. Driving along at about 50 and all of a sudden there's about an inch of wobble in both directions. It does it for a few seconds then goes back to normal.
15th Apr 2015 10:26am |
Check bushes first , drop links track rods that sort of thing before looking at the expensive answer . 2008 MY Supercharged
15th Apr 2015 10:33am |
I checked all those and replaced a lower arm very recently. The feeling of this is very immediate on and off and feels hydraulicy through the wheel. What level should the pas fluid be at? |
15th Apr 2015 10:36am |
bag 933s Member Since: 21 Apr 2015 Location: south west Posts: 13 |
i seem to have this issue also around 50-70 there seems to be a vibration or lumpiness i thought maybe a wheel balance issue, but im replacing rear discs and pads this week, but pulling away and under load its perfect just at motorway cruising speeds it noticeable |
21st Apr 2015 12:56pm |
mine turned out to be 5mm spacers cast and not turned so all over the place on each wheel....drives lovely now, the love is back |
24th May 2015 3:42pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
"5mm spacers cast and not turned"
24th May 2015 3:47pm |
5mm wheel spacers...not hub cantric.... very cheap cast items.....they served no purpose what so ever, took all 4 off and she drives lovely now |
24th May 2015 4:33pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
A tired Power steering pump would probably do it, or if the belt is slipping. |
24th May 2015 6:10pm |
Just to round this off, as another poster mentioned I had a sticking caliper. Changed it and no more issues. |
31st May 2015 6:48pm |
